confirm current plan. How many data I can use per month?
Bwong2
HALIMACS
@Bwong2
what perhaps should be mentioned is that none of us here are public mobile staff – we are all just other customers like you.
We don’t have access to your account to give you specifics of the plan you have selected, and thus your data allotment particulars.
@Bwong2  PM is pre paid you can only use what you paid for what plan are you on ? Check your usage like this
simply try refreshing the page to check data plan / mins / add ons
hairbag1
@Bwong2
depends on which plan have you selected. Log in on the account should show you.
Please log into you Self Serve account through the wensite or mobile app for your plan details.
