07-22-2019 04:37 PM - edited 01-05-2022 06:02 AM
I just purchased a motorola g6 and cannot find it on the list of compatible phones. Moto g5 and g7 are listed but not the g6. Will the g6 work with public mobile?
07-22-2019 05:50 PM
@stevehill no issues. Here are the official specs:
https://www.motorola.com/us/products/moto-g-gen-6
LTE:
B1
B2 (1900)
B3 (1800)
B4 (1700/2100)
B5 (850)
B7 (2600)
B8
B12 (lower700 abc)
B13 (upper700)
B17 (lower700 bc)
B20 (roaming)
B25 (1900+)
B26 (850+)
B28 (700 APT)
B29
B30
B38
B41 (Full)
B66 (AWS3+4)
UMTS: B1, B2,B4, B5,B8
CDMA: BC0,BC1,BC10
GSM: B2,B3,B5,B8†
07-22-2019 05:22 PM
@stevehillAs long as it works on the Telus network it should be fine. It is best to try it physically rather than relying on the database.
07-22-2019 04:41 PM
It should be compatiable if it is the US version.
| HSDPA 850 / 900 / 1900 / 2100 & CDMA2000 1xEV-DO | |
| 4G bands | LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 13(700), 17(700), 20(800), 25(1900), 26(850), 28(700), 29(700), 30(2300), 38(2600), 41(2500), 66(1700/2100) |
