05-12-2021 12:21 PM - edited 01-06-2022 02:02 AM
hi,
If I change my pl;an in the middle of my 30 days will I be charged the full amount for the new plan or just the difference between the two plans.
thanks
05-20-2021 04:40 PM
05-12-2021 03:28 PM
@hTideGnow wrote:If you are changing you plan because you are running out of talk minutes or data, you would want to Change it now, then the 30 days will reset today and next renewal will be 30 days later.
If you have no short of data or talk time at the moment, you will pick the choice to change it on the next renewal cycle.
I do not think it is a good idea to change plan NOW as he will be losing paid service left until his billing cycle. It could be just SMS but still... If you have paid $15 and you are in the middle of cycle and start NEW cycle today, $7.50 is lost.
Better is to schedule plan change at next billing AND buy some data/minutes as add-on.
05-12-2021 03:12 PM
05-12-2021 12:32 PM
You would be charged for the new plan at the full price. It is recommended to change a plan on next renewal so you don't lose any unused minutes/texts or data.
05-12-2021 12:30 PM - edited 05-12-2021 12:31 PM
Anytime you make a plan change, if it's an immediate one, your billing cycle starts from that date.
Remember that public mobile cycles run on 30-day rotating terms - not monthly.
05-12-2021 12:30 PM
@Anonymous got the choices down pat for you.
You might have to do a little math if you're trying to decide whether it's worth purchasing the add-on or waiting the number of days till the next renewal takes place.
Depending on what plan you're currently on, you may also wish to consider upgrading to a higher data allotment plan and making that change effective on your next renewal.
05-12-2021 12:28 PM
if I changes my plan today will my billing date be 30 from now or still on my old billing date? thanks
05-12-2021 12:24 PM
@salyward3008 : No pro-rating here. Set it to change on your next renewal if you like your money. But you're probably asking due to being out of data. You can buy add-ons, ask for an early renewal or change plan immediately. No pro-rating.
