changing plan
06-18-2024 12:53 PM
can I switch to the new 3GB data 4G speed plan and maintain my bonus that I presently have
Plans
06-18-2024 05:15 PM
You will keep all of your yearly bonus data and minutes.
you will also keep all of your referrals as points going forward.
06-18-2024 03:28 PM
will I still keep the bonus from the two people that I got to sign up and my yearly bonus
06-18-2024 02:47 PM
The 3GB plan is available for new activation only, there is $19 1GB 4G plan available ti existing customers.
all of your bonus minutes and data from holiday will be let’s, you may lose your last data bounce 240GB if you downgrade
06-18-2024 01:13 PM
data bonus due to public rewards migration no if you downgrade but other data/minutes bonus will still be in your account.
06-18-2024 01:11 PM
referral bonus yes
06-18-2024 01:05 PM - edited 06-18-2024 01:07 PM
Note that the $21 3GB plan is normally available for new activations only so to switch to it you must have received it as a targeted offer. In which case it will be an upgrade and you can certainly keep all of your add-on data.
06-18-2024 12:59 PM
hi @Manny4
depends on the type of bonus
if you have the special loyalty bonus that has a 150 days expiration, then you will loss it if you downgrade your plan (but upgrade is ok)
if you have those 2GB from last couple Decembers, then yes, they will be there still
