changing plan choices 3G
CB51
Available plans for $reward members
On my account , change plan tab only lower plan showing, on 3G sspeed choice.
@on2wheels   PM is giving a push to the LTE and 5G plans at the moment, and hence only keeping $15 and $25 plan on 3G
they used to have $30 and $35 but now the next one from $25 is $39 for 20GB.  It is a bit more, but the data amount it includes is very well worth it
on2wheels
Does it cost PM more to provide a larger selection of 3g plans? There's a big gap between the 1GB plan and the 20GB plan, seems like a huge market they don't serve, or perhaps just upgrade everyone on the 1gb plan to 2 or 3gb and be done with it(?)
HALIMACS
@CB51
Perhaps your screen size settings is displaying these options out of view?
Try logging in on the opposite device from where you are currently logging in from.
If using mobile, try desktop/laptop.   Or vise-versa.
Are the 4G plan offerings now visible?
@CB51 look at the top there is 3G and 4G up there. Choose the 4G plans and scroll through using the yellow arrows.
Edit, oh you weren't looking for the 4G...but once you hit the yellow arrow ONCE, you will need to move the cursor down to continue to scroll downwards to see more options.
@CB51  If on computer viewing the plans use the arrows to scroll thru plans on mobile there will be arrow on the bottom to scroll thru plans
