09-09-2022 10:31 AM
cant sign into my account, cant make calls, cant do anything. but my credit card has been charged. basically got done all 4 steps with the new sim card and the website just kept doing some loading thing. so i have no idea what happened.
08:36 PM
09-09-2022
10:33 PM
computergeek541
go to store buy it vouchers and call *611 to added and do reactivated.
not works open ticket with PM support and ask them fix it
At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
edited by computergeek51: crossed out informatoin was provied more than 10 hours earlier
09-09-2022 02:01 PM
just did that. so my phone number i selected is on my phone and my sim card number seems to be registered because if i try to start the process again it wont let me use that sim card number. however the phone cant send or receive calls and i cannot login to my account that was supposed to have been created.
09-09-2022 01:40 PM
theres nothing to try, the account didnt get created somehow but now it wont let me activate the sim card number so that part must have went through.
09-09-2022 10:38 AM
Did you get any error codes at all, you only attempted once and got charged and didn't keep trying because you didn't see it active? Sometimes there is a glitch where ppl didn't think it went through and try a few times and get charged multiple times but I haven't seen that in the community in awhile.
09-09-2022 10:33 AM
@shawnharris4343 did you try to take the sim card out and re-insert into the phone again,? or try on another phone?
do you get a message "SIM not provisioned" , "No network", "no Sim"?
it could be just a sim provisioning error, please open ticket with PM support and they should be able to resolve it quickly
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
