cant rememer pin
11-19-2024 07:58 PM
11-22-2024 10:33 AM
11-19-2024 08:02 PM - edited 11-19-2024 08:03 PM
Hey @Goodyearave
If you need to reset or change your account PIN, this process requires direct assistance from a Customer Support Agent. This guide is applicable to customers with an account PIN. Resetting or changing your account PIN cannot be done through *611.
Steps to Reset or Change Your Account PINContact Customer Support
- Submit a ticket to our Customer Support Agents to request a PIN reset or change. You can start the process here.
Check for Responses
- Keep an eye on the Public Mobile Community for a response from a Customer Support Agent (CSA), or check your email for notifications indicating a response.
Follow Instructions
- Once contacted by a CSA, follow their instructions to securely reset or change your account PIN.
Account PINs are essential for accessing certain account features, so keep your new PIN secure and confidential.
The ability to reset or change your account PIN is available to customers who have set up an account PIN already.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
11-19-2024 07:59 PM
hi @Goodyearave
the account pin? you can reset it using this link
