05-06-2019 09:04 PM - edited 01-05-2022 04:48 AM
I transferred my phone from virgin mobile to public mobile about 4 hours ago and can’t receive calls or texts. What do I do?
12-04-2019 06:11 PM
@Noel64Check your online profile to see if everything is okay. Then try these tricks listed here:
12-04-2019 05:58 PM
ive been with public mobile for 7 yrs i dont have this issue just now i cant call or receive call and text im payed for this month december what should i do need your help
05-06-2019 09:13 PM
Send a private message to the Moderators by clicking here. Make sure you provide the number you are trying to transfer, and the port transfer request information you shared at activation.
05-06-2019 09:13 PM
@Carolinemeadus wrote:I transferred my phone from virgin mobile to public mobile about 4 hours ago and can’t receive calls or texts. What do I do?
Your number has not been tranafered over (yet). I would double check that you have your Virgin Mobile account number handy. Perhaps, wait a few more hours. If it's still not done after that time send a private mesaage to Moderator_Team using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
In the meanwhile, your incoming comnunications are still going to Virgin Mobile.
05-06-2019 09:08 PM
@Carolinemeadus- If you are able to call/text out, then that means that your number port (transfer) is not yet completed. Usually, ports from cell carriers take only a couple of hours. However, in some cases, the old carrier blocks the transfer so that they can contact the client and try to convince them to stay. It could also be that there was something wrong with the port request. Remember that your account with your previous carrier MUST be active when porting the number out. Have you restarted your phone? Does your OLD SIM card still work (it should). If so, leave it in the phone until it stops working. That's when you know that the transfer is complete (hopefully)> If it doesn't complete by the morning, I would send a private message to the moderator team and ask them to look into it.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 8AM-Midnight(EST) & Sat/Sun 8AM-10:00PM(EST)
