cant make a call
mike136
CSA_PM
Customer Support Agent
Hi
Due to a system issue the authentication message was posted to public. Please ignore it and respond to the private message I sent .
CSA_PM
Hi there. I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@mike136
If you just activated a new SIM/account. Contact a CS_Agent to investigate the issue.
If you are an existing member, check to see if there is an outage in your area.
https://istheservicedowncanada.com/status/telus/map
@mike136  Did you just join public mobile ? If yes try and reboot the phone first . If your existing customer can you log into your account and confirm its status is it active or suspended , if suspended you need make manual payment .
also check
Outage map in your area:
If it’s active and no outage in your area also try adding in 1 infront of the 10 digit contact if still no luck
send  a  private message   To CS_Agent
