06-09-2022 02:44 PM
i have 250mb each month. it was ok before but cannot connect to internet this month. i only used 12-15 mb up to today.
06-09-2022 03:07 PM
@Sharonz You can always purchase some back up data for the times you've run out of plan data before renewal. Price is a little steep at $15/1GB but it's non expiring so any left over data simply keeps rolling over until depleted.
06-09-2022 02:57 PM
this might be the reason. 30 days not monthly. Thanks
06-09-2022 02:57 PM
250MB isn't that much and can be used up quite quickly, many times it may be inadvertent. In any event, if you are quite sure it is an error, feel free to connect to a CSA to investigate for you.
06-09-2022 02:55 PM
i don't think so.
06-09-2022 02:53 PM
@Sharonz hi then it is all used up sorry
06-09-2022 02:52 PM
no data is showing.
06-09-2022 02:52 PM
If there is no line showing in your data/add ons then the data has been fully consumed, unless there was an error and they didn't reset the counter. If you think that is the case you can reach out to a CSA to investigate.
06-09-2022 02:51 PM
Use the date at the top of the overview to figure your renewal date. Then look at the usage logs to add up your usage since that date.
If you don't see a data line item in your my data & add-ons then you've used it all. Also be sure to understand that this place is 30 days, not monthly.
06-09-2022 02:50 PM
What is your plan renewal date?
Check data usage settings on your phone, it will most likely NOT reset on the same day as your plan renewal date.
Also, try resetting your phone.
06-09-2022 02:50 PM
@Sharonz hi can you check in your self serve account under plans and add ons to see if any data is showing there
