Addon
06-09-2022 12:05 PM
06-09-2022 02:55 PM
If you don;'t see it in data/add ons section, check your available balance and the amount is most likely there and just complete the second step and you should be good to go.
06-09-2022 12:47 PM - edited 06-09-2022 12:47 PM
You can check by login to your account and look under My Data & Add-ons. If it is in the list of your plan plus the add-on your purchased.
If it is not on the list, you missed the 2 steps.
1 - Charge amount of the add-on into your account
2 - Make the purchase of the add-on.
06-09-2022 12:08 PM - edited 06-09-2022 12:10 PM
@bidsanand login to My Account. check if your add-on is on the Overview Page, under My Data & Add-ons
OR check the Plan details page,
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/ChangePlanLandingPage/
if you see your addon in one of those two places, then yes, the add-on is still active
