08-15-2022
12:29 PM
08-15-2022
05:20 PM
computergeek541
08-15-2022 05:19 PM - edited 08-15-2022 05:19 PM
08-15-2022 03:36 PM
do you get SMS from your old provider about Transfer then reply no is will be cancel porting request.
08-15-2022 12:35 PM
coming in
08-15-2022 12:35 PM
Whichever way it goes, do NOT reply Yes on request having SIM in your phone.
Request will fail.
If you are porting to PM, do not reply Yes while having OLD SIM in your phone.
If you are porting OUT of PM do not reply Yes while PM SIM is in your phone.
08-15-2022 12:33 PM
HI @Joeabbas porting out or porting in?
If it is a porting regarding another provider, you don't have to do anything. Part of the porting requiring you to repy YES to a text, you just don't need to reply and the porting would not continue
But if it is porting from a landline or from VoIP , then you have to open ticket with PM Support to cancel the porting:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
08-15-2022 12:32 PM
Which direction? Coming in or going out? Did you confirm the transfer text?
