09-18-2018 03:01 PM - edited 01-05-2022 01:50 AM
Hi,
I need to activate 20 more SIM card with same credit card. But credit card can't go through. What should I do?
09-18-2018 03:56 PM
@Aya wrote:Visa said nothing wrong with this card.
I think public mobile think this is not proper activation or something...
Well you are 5 ahead of most of us who ran into a roadblock at 3.
09-18-2018 03:24 PM - edited 09-18-2018 03:26 PM
@Aya You have to admit, 8 cards, let alone 28 cards seems to be excessive for one person
Oh... maybe, wait a little and see if you can do it then.
09-18-2018 03:23 PM
09-18-2018 03:22 PM
@Dunkgirl, it has been a while since there have been a report of credit card failure when used in multiple accounts. Maybe Public Mobile has fixed the problem. It is a strange glitch but that how it was back then. No surprise if the credit card company reacts to the same purchase many times over in short period of time. Come to think of it, a friend at work tried to activate two Koodo accounts back to back online using the same credit card. His second attempt was blocked by the credit card company due to anti fraud measures.
09-18-2018 03:21 PM
@will13am wrote:
@Aya wrote:yes, first 8 of them worked
Wow, you did good. In the time that I have been here, I have only ever seen customers talking about failing at the third account similar to my experiences. This was not enough to trigger fraud alert at the credit card company. Eight times is probably enough to have the credit card company lock down the card. That should be an easy one to check on.
Agree, contact you Credit Card provider and ask them if they locked it.
09-18-2018 03:18 PM
09-18-2018 03:11 PM
09-18-2018 03:11 PM
Sorry, we are unable to verify your card at this time. Please ensure your card details are entered correctly and try again. If you continue to experience problems, contact your card provider for more information.
I contacted Visa and they said nothing problem...
09-18-2018 03:10 PM
@Dunkgirl wrote:
@Aya wrote:Hi,
Repeated transactions can often throw a flag. If it didn't let you do all of them the account was probably flagged and you would need to contact your credit card company.
This is true too. The self serve glitches preceed fraud detection at the credit card company.
09-18-2018 03:05 PM - edited 09-18-2018 03:11 PM
@Aya wrote:Hi,
@will13am wrote:there is an unexplainable bug with the self serve system that seems to not allow the same credit card to be used across more than 2 accounts.
09-18-2018 03:05 PM
@Aya, there is an unexplainable bug with the self serve system that seems to not allow the same credit card to be used across more than 2 accounts. I was able to do it for 3 accounts but it took a bit of a workaround to do it. The problem seems to be isolated to the initial activation. Once I activated, I was able to switch back to the card which I tried to use for activating a third account. This sounds rather crazy considering each account is its own entity and not linked to other accounts. This is the behavior. One solution could be to work with two or more credit cards. Another option is to buy vouchers. recharge.com is a good online resource for getting vouchers.
09-18-2018 03:03 PM - edited 09-18-2018 03:03 PM
@Aya wrote:Hi,
Did it work on the first few or none?
09-18-2018 03:02 PM
@Aya wrote:Hi,
What does it say when you try?
Is your credit card expired?
