can't receive code
08-29-2023
12:41 AM
08-29-2023
02:52 PM
computergeek541
I lost my SIM card and I've already bought a replacement but I can't log in to my self serve account to transfer my subscription. It sent a code to my phone number but I don't have a SIM to receive my code and it doesn't have an option to send the code to my email. How can I work around this?
My Account
Service
08-29-2023 01:24 AM - edited 08-29-2023 01:26 AM
@yeyuui , a Telus store will not help you with a Public Mobile account. Please send a CS_Agent a private message to do your SIM Card swap for you!
08-29-2023 01:22 AM
It now shows this screen every time I try to log in so I think I'll just go to a Telus store tomorrow and hopefully they'll be able to help me.
08-29-2023 01:19 AM - edited 08-29-2023 01:21 AM
@yeyuui , will this link change the way it asks you to login?
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
Edit: If not please send a private message to ask a CS_Agent to do a SIM Card swap for you.
You can send a private message to a CS_Agent using the link: -> https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Customer Support Agents are available from:
- Monday to Sunday: 9 AM to 10 PM EST
A CS_Agent will respond back in your Community mailbox (envelope icon) at the top right of this page to the left of your community avatar on your computer or by clicking on your avatar on your device.
08-29-2023 01:14 AM
Yes but it's the same on the app too 😓
08-29-2023 01:13 AM - edited 08-29-2023 01:14 AM
@yeyuui , sorry! I don’t know why it looks like that! 😞 Are you able to try on the Public Mobile app? If not please try @MetaMorpheusMob suggestion.
08-29-2023 01:09 AM
this is what it shows for me
08-29-2023 12:58 AM - edited 08-29-2023 01:03 AM
08-29-2023 12:56 AM
It doesn't give me the "Didn't get the code?" option, it only has "Resend code", and when I click on it, there's only the option to "send text" or "send voice message".
08-29-2023 12:44 AM - edited 08-29-2023 12:53 AM
@yeyuui wrote:I lost my SIM card and I've already bought a replacement but I can't log in to my self serve account to transfer my subscription. It sent a code to my phone number but I don't have a SIM to receive my code and it doesn't have an option to send the code to my email. How can I work around this?
@yeyuui , if you select “Didn’t get the code?” does it give you other options like it does for me in screenshot below?
Edit: After you’re able to login:
Follow these steps to update the SIM number associated with your account:
- Log in to the Public Mobile app (select + symbol on bottom left) or My Account
- Go to the ‘Profile’ tab
- Select the pencil icon next to your current SIM number
- Enter your the 16-digit code of your new SIM
- Select ‘Save Changes’
Or use this direct link: https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
