07-28-2023 02:09 PM
I am trying to buy $15/month plan, but its not giving me any option to buy the physical SIM card.
07-28-2023 04:21 PM
@Rubalking if you have not ordered yet, you should got it on person from Telus/Koodo store or Amazon for quicker turnaround
07-28-2023 04:20 PM
Thanks for the advice, it worked
07-28-2023 03:29 PM
@Rubalking wrote:I am trying to buy $15/month plan, but its not giving me any option to buy the physical SIM card.
@Rubalking - I believe it should be an option somewhere if you are on the app buying a plan. But, if it is not, then you can order one online with public mobile here: https://store.publicmobile.ca/cart
Note, this normally comes through regular letter post by Canada Post.
07-28-2023 02:13 PM - edited 07-28-2023 02:14 PM
@Rubalking You need to have the physical SIM card in hand to activate the plan . Quickest way to get one is call around to local Telus Koodo store for availability. Pick one up and activate using the new PM app
add
unless your phone supports eSIM you can download it right from the activation process on the app
