03-04-2021 06:08 PM - edited 01-05-2022 05:29 PM
says to contact, don't know where to do. need a mod since im locked out
03-04-2021 06:14 PM
@jamesm wrote:says to contact, don't know where to do. need a mod since im locked out
Hi @jamesm what do you mean you are locked out? do you mean you cannot log in your self serve account?
Two ways to contact the moderators:
It may take 2 - 48 hrs (much less these days) to receive a reply from the moderators. Keep checking the envelope icon on top right for a number to pop up. That would be the moderator’s reply.
I hope this helps
RosieR
03-04-2021 06:11 PM
did you try Forget password link? if you have waited an hour, you can try agian
or if you need Mod:
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request moderator assistance, or you can also use this direct link instead https://widget.telus.tiia.ai/publicmobile/publicmobile.html, then type "Submit a ticket", select Account-specific issue, then select I need a human now. Follow the prompts to submit a ticket.
2. Or you can Send a private message to the moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
03-04-2021 06:11 PM
Contact a moderator (Public Mobile representative) for assistance:
(second option below is easiest to submit a ticket)
