03-04-2021 06:24 PM - edited 01-05-2022 05:29 PM
Hello. I am wondering if the Samsung A21 is compatible with the network? I do not see it on the drop down list.
Thank you
05-04-2021 10:06 PM
@Batman96 wrote:Ok so the 2 out of 5 doesn’t matter at all ? Thank you for the clarification
It does matter to some extenet, but LTE is not a requirement to use Public Mobile., except for the official goverment emergency alert system. LTE does get used for data and text messaging, but those also work on the 3g network as well.
05-04-2021 09:52 PM
05-04-2021 09:49 PM
@Batman96 wrote:I’m looking at buying A Samsung A21 phone and I have looked up compatibility and it says 2 bands of out of 5 does this mean it’s compatible but not as much as other models and brands ?
The only bands that you absolutely must have (or else phone calls won't work) are the 3g bands at 850 and 1900MHz (band 5 and 2 on 3g).
05-04-2021 09:47 PM
03-04-2021 06:26 PM - edited 03-04-2021 06:40 PM
@Deno wrote:Hello. I am wondering if the Samsung A21 is compatible with the network? I do not see it on the drop down list.
Thank you
Looks like it should be fine. Check willmyphonework.net. edit...The G A21 isn't on their list either but the phone will work on PM network.
03-04-2021 06:25 PM - edited 03-04-2021 06:29 PM
Thank you
It's fine. A phone doesn't have to be in Public Mobile's list to be compatible. The phone only needs to have a SIM card slot and be at least compatible with HSPA on bands 2 and 5 (1900MHz and 850MHz).
03-04-2021 06:24 PM - edited 03-04-2021 06:26 PM
Samsung A21 should work on PM
