04-15-2026
04:25 PM
04-15-2026
05:00 PM
computergeek541
old card no good can not add new card,Update Card Information not working
04-17-2026 04:23 AM
downloaded the app on my brothers phone asked if i wanted to re-activate my account said yes and the next pop up was enter card details did that and everything working fine...WHAT A NIGHTMARE .thank you for reaching out have a great weekend.
04-16-2026 08:33 AM
hi @cigarsmoker
if you have selected Public Mobile RTR, that is a real time transfer, you should see the $100 within 15 mins. Login My Account using browser with Incognito mode to confirm, check the Payment history page. PM will use the money for renewal. Or if subscription was suspended earlier, the system should renewal with the funds you just loaded
if you have selected Public Mobile, it is just a voucher and they should have given you a voucher code to load manually
04-16-2026 08:19 AM
thank you for the quick reply.i added a $100.00 topup with MUSKBIRD checked account it shows funds $104.00 will this be automaticly added to my phone do i have to do anything.
04-16-2026 06:56 AM
@cigarsmoker try again using browser with Incognito mode and try using Public Mobile app
If both fails, and it is not urgent to make payment, wait 24 hours and try using both browser and PM app again
But if you need to make payment urgently to resume service, you can get a voucher from SDM/Rexall/Loblaws/Cantire and then load the voucher using *611 on your phone (or 1.855.4PUBLIC from another phone) to resume service first and then try updating the card again later
(you can also buy a voucher online with a fees from muskbird.com/ding.com/recharge.com or a complete list of stores carrying PM payment vouchers: https://publicmobile.ca/en/payment-voucher )
04-16-2026 06:51 AM
thats the problem when i try to highlite the add card info it does not work only the postal code section works
04-15-2026 04:39 PM
using the Public Mobile app, log in to your account > Payment (at bottom of screen) > scroll down to find Update Card Information...in there, you'll be able to add the new payment card info. I just tried it and seems to work ok.
04-15-2026 04:31 PM
Try this link see if it will work for you.
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
