can my physical sim card in use be switched to esim, and how?
Fangfang1
I currently use a physical sim card, I want it be switched to the form of esim can anyone tell me how to do this?
@Brumas1
hang on to it, it wouldn't be too long  🙂
Brumas1
The sooner the better for switching from SIM card to e-SIM.
XionBunny
It seems likely in the future honestly, with the amount of customer demand for it as of late, so here's hoping the ability is supported sooner than later.
@Fangfang1  No sorry eSIM is only for new activations for now . Hopefully soon though existing customers will be able to get
dust2dust
There is currently no way to switch from one to the other. If you want to use your esim phone here then you would need to start a new account.
