can i keep my current phone number
sid1986
Martin
Legend
Legend
Hello,
When porting, remember to NOT close the account of the carrier that you are leaving. If you do so before the porting process is complete, porting will fail, and you will likely lose your number.
When porting is successful, your former account will be automatically deactivated.
Welcome to Public Mobile!
Rick
If its active you can port the number to Public Mobile but you will need either valid PIN, account number or IMEI to complete the process either when activating or on self serve. If the number is not active you will need to get a new number.
@sid1986 To keep your phone number, your contract with your old carrier must remain active until you finish transferring the number.
NDesai
Yes you can.
makkahn28
If you are porting from another Carrier, Yes you can
sid1986
can someone pls reply
