Monday
Monday
hi @Annie31
can you check if your removed the old carrier sim card or disabled the old esim?
and you can receive inbound calls? how about data? only long distance calls not work? Try Reboot your phone and Reset network settings
Monday - last edited Monday
other thing to check. can you confirm if you removed the old sim?
And enable the PM sim, change the label to Primary. Reboot phone and Reset network settings. Try calling again. Also confirm if you can use mobile data
if still unable to call, please tell us what phone do you have
Monday
I cannot make calls, only to my other phone
International long distance or within Canada?
If within Canada, reboot the phone and try again
If international, you might need add-on, which country you are calling?
Monday
