3 weeks ago
3 weeks ago
We just didn’t pay our bill apparently lol all good now
3 weeks ago
You could also try a network reset of your phone. Note: this will erased any saved Wifi passwords.
3 weeks ago
What is the make and model of your phone?
With the 3G shutdown you will need VoLTE to make and receive calls. Here is more information on VoLTE and enter the IMEI of your phone to see if it is compatible with PM network.
3 weeks ago
I also am having the same issue.
no Telus outage in my area.
3 weeks ago
Is texting and data working?
you can check Telus outage map
https://www.telus.com/en/bc/outages
Also can try a simple reboot of your phone.
which model phone do you use? Is it VOLTE compatible with PM network?
