04-03-2024 05:22 PM
04-03-2024 05:44 PM
if you have access to a different unlocked cellphone, try your PM sim in that phone (as long as it's not esim, that is !)
04-03-2024 05:43 PM
@loca did you just activate the account and port in your number??
04-03-2024 05:40 PM
I try 3 G but nothing
04-03-2024 05:28 PM
receiving calls it is the issue
04-03-2024 05:27 PM
Canada, I checked mode and DND , all good
04-03-2024 05:25 PM
@loca - Can you try using your old SIM card from your old provider if you just activated.
If it was long ago, then try 3G.
04-03-2024 05:24 PM
I can call and SMS
04-03-2024 05:24 PM - edited 04-03-2024 05:24 PM
@loca - Are you in the States or in Canada?
Is silent mode or DND on?
Try 3G if you are in Canada
Or in the states try T-Mobile and put it to 2G OR you don't have a roaming add-on or Canada-US plan.
Or did you just activate your PM service and ported a number?
04-03-2024 05:23 PM
Did you recently port your number?
Can YOU call or SMS anybody?
