call issue [urgent]
10-22-2018 11:05 AM - edited 01-05-2022 02:15 AM
10-22-2018 01:24 PM
Login to your account to make sure it is not suspended.
Are your physically ally still in your home province and/or are you near a provincial boarder?
10-22-2018 12:25 PM
Can you receive any calls on your phone?
10-22-2018 11:38 AM
Perhaps add a long distance add on for $8 for 200 mins and it might work for the short term. Otherwise you can temporarily use an app like Fongo to make a call over wifi or data.
10-22-2018 11:34 AM
Good on you @demon1102 for contacting the Moderator Team directly already.
Unfortunately sometimes it can take a while for them to get back to you when their workloads are busy. Some forum members have been posting wait times of 48+ hours.
Hopefully they'll get around to you sooner rather than later.
10-22-2018 11:23 AM
@stonechucker wrote:Is the number you're calling a "newish" area code and local-exchange combination? Public Mobile seems to have a problem keeping their 'province-wide' allowed calling lists up to date.
There's also the chance that you have a provisioning issue. Contact the Moderator_Team via private message, provide your phone number, your account number, and PIN, along with a complete description of the issue, including the number you're trying to dial.
My phone # is 506-xxxxxxx and I was trying to cal 506-xxxxxxx.
I contacted the Moderator_Team before but I didn't get any reply.
10-22-2018 11:21 AM
@ShawnC13 wrote:
@demon1102 wrote:BTW, I PMed the support team. It has been a while and nobody replied me yet.
What plan do you have?
I have unlimited provinal talk plan
10-22-2018 11:18 AM
10-22-2018 11:18 AM
10-22-2018 11:16 AM
10-22-2018 11:12 AM
It didn't go through. I followed what you said but that didn't work as well.
10-22-2018 11:09 AM
Did the call go through (i.e. you got a message saying "long-distance charges may apply", but the call still worked)? If so, there is nothing to worry about.
If the call did not go through, try adding 1 (or +1) in front of the number and trying again.
