06-06-2023 01:50 AM
I used to have call forwarding set to forward my calls when not available(phone off) to another number. It no longer works. 62(10 digit number)# gives message " connection problem or invalid MMI code"
06-08-2023 02:56 AM
I have LTE enabled. No option for VoLTE. Galaxy S7
06-08-2023 01:56 AM
@drem wrote:what is volte??
VoLTE refers to the ability to make or receive phone calls while connected to the LTE network.
06-07-2023 11:14 PM
what is volte??
06-06-2023 02:25 AM
With the roll out of volte, call forwarding conditionals broke. If you have volte enabled then support can do something to fix it. If you don't have volte enabled then that seems to be that.
