06-09-2021 11:51 AM - edited 01-06-2022 02:28 AM
06-09-2021 12:06 PM
Are you trying to purchase $5 add-on for 500 Canada wide minutes ?
Purchasing add-ons is a two step process. You need to add then purchase it.
To purchase Add-Ons using your Self-Serve account, follow these steps:
06-09-2021 12:01 PM
@raider1234 : Do you see at least $10 in your Available Funds? If so then you need to go back and purchase the add-on...again. It's a non-intuitive 2 steps. Add money, buy add-on. You've likely done step 1.
If you did all that then which add-on and where are you..Canada or US?
And maybe restart the phone.
06-09-2021 12:01 PM
It sounds to me that you have purchased the wrong add on unless you are trying to use a US roaming add on. You can contact the moderators to correct your mistake if this is the case.
What was your intention when purchasing the add on? What plan are you on? The $15? Do you need the $5/500min canada wide calling add on?
