bonuses
zelig1
I did not get my xmas bonuses as I accidently deleted your email.
8 REPLIES 8
popping
@zelig1
You replied to my post "It worked"
You should tag my post as the solution to your issue.  Otherwise, other member looking for answer does not know how you get it working.
zelig1
It worked. Thanks
@zelig1 wrote:
I got the text but accidently deleted it.
@zelig1   if you got the text already, then you can simply send YES2 to 4911 and it will work
Yummy
Email is not important. Wait for SMS from PM
popping
@zelig1
PM sent the offer from short code 4911.
Send YES2 to short code 4911 and PM will reply saying PM had added the data and international minutes add-ons to your account..
zelig1
CGO
just reply YES2 after to receive the message on phone. no worry about emails.
@zelig1   email doesn't matter, it is the text that you need
PM is still sending text to the rest of the customers.  You should get it today or tomorrow
If you still not receiving anything tomorrow, you can then open ticket with PM Support and they will add the bonus for you
