b
dough13
2 REPLIES 2
HI @dough13   I see you deleted everything, are you able to login now?
@dough13 wrote:
@CS_Agent I need help log in into the self serve its the first time in awhile to make sure a payment went through and it sends an sms verify code  to the phone that does not go through. how will i log in? Ps i dont have access to email either (need sms to reset the password to email as well)
HI @dough13
is your phone suspended and you cannot receive the SMS?
Open ticket with CS agent and they will help you to change your login to a new email address you have access to
https://publicmobile.ca/chatbot.
First type Forgot Login,
