12-18-2021 09:49 AM - edited 01-04-2022 04:55 AM
once you have purchased an add-on and the 10 day period is up how soon can you purchase another add-on and is their any limit to the number you can purchase over a three month period
12-18-2021 12:40 PM - edited 12-18-2021 12:41 PM
@Anonymous wrote:for Re-Purchase Add-ons you need to wait 25 hours after the expiry first Purchase Add-ons or you need to Contact Customer Support Agent by CS_Agent, right a way to do it for you....
There is no guarantees that a CSA agent can do this “right away” for you.
During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
12-18-2021 12:36 PM
12-18-2021 09:57 AM - edited 12-18-2021 09:59 AM
After 24 hours, you can repurchase the same US Roaming addon
EDIT: There is no limit to the amount of consecutive add-ons you can purchase.
If you are going to be in the US for a month or more, it'll be far cheaper to purchase a local pre-paid SIM card and use it while there.
You can revert your Public Mobile plan down to the $15 plan to maintain it - or even suspend it for up to 90 days without paying at all.
