add-ons for a month
03-06-2020 07:36 PM - edited 01-05-2022 09:49 AM
03-06-2020 07:52 PM
@GlennK you might also want to look into getting a local SIM, depending upon the cost of the add ons. You can also look at downloading the voip app TextNow and use it over WiFi to make/ receive/ send calls and texts.
03-06-2020 07:40 PM - edited 03-06-2020 07:40 PM
USA roaming Add-ons10 day period start as soon as you buy it so you can't buy three at once.
Also it's two steps to buy a add-on. Guide below for you.
03-06-2020 07:39 PM - edited 03-06-2020 07:44 PM
@GlennK wrote:Stupid question......can I do 3 ten days add-ons in one transaction or do I have to wait for every 10 day period to expire before starting another?
If you're asking about the roaming add-ons, then it's not a good idea as they will all expire after 10 days, it's better to stagger them to get the best value from them.
Edit: Another thing to keep in mind that sometimes add-ons become unusable when two add-ons have the same features in them, ie: talk or data, so it's best to purchase one after the other.
03-06-2020 07:38 PM
