09-04-2023 11:45 PM
how activate add on.i buy for 30$ 3Gb data and talk unlimited.my curent plan 15$ no work more.i try apdate new plan 39$.its say next month only when cicle.my phone no work.abmnd no data.but in account say i have 3Gb data.how i activate this.please and thank you💜
Service
09-05-2023 06:39 AM
@psysuzy No number to call you will have to message support and see if they can reverse it for you here the link
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-05-2023 04:22 AM
do you know number where.i can call and talk with agent.i want cancel roaming and change plan for 39
09-05-2023 04:19 AM
hi there thanks.but i already spebd 30 for roaming data.and i want cancel roaming.abdvtry get this plan now
09-05-2023 04:17 AM
hi there.yes i buy roaming.how i can cancel this add on.and back my 30$
09-05-2023 01:28 AM - edited 09-05-2023 01:29 AM
If you're out of data and you want to renew into the $39 plan now, you can. If you already scheduled the change to take effect on your renewal date, just cancel that and then renew into it now.
09-05-2023 12:01 AM
It sounds like you bought the roaming add-on when you say talk. What is not working? Can you call out? Call in? Text out? Text in? Is your account active?
