activation of my sim card
Mathilita
how can i activate my sim card with a paiement voucher?
1 REPLY 1
@Mathilita
yes, you can  activate with voucher and not credit card.    What you need to do is not  to activate from the Activation portal directly. instead, you need PM support to help:
  1. Open ticket with PM support by direct message them:
  2. PM support reply and ask you for the sim card number, an email address used for the activation (login for My Account).
    They will activate the account with the sim card.  The account will have status SUSPENDED.
    PM Support will then sent you the login and password.
  3. Once the account is setup, you can login to My Account and load your voucher to finally activate the service.
