activation not working for calls
vivienne
I activated my SIM card yesterday but I'm still unable to make calls. Texting works fine. I'm seeing a few bars but I'm unable to see the network.
Have tried turning phone on and off, changing the SIM card to a different location, popping it out but still the same results.
My phone is a Samsong A1core
help!
What do you mean by "changing the SIM card to a different location" @vivienne ...do you mean another phone? And still not able to make calls?
What happens when you try to call the phone number you activated with from another working line/land/cell..?
@BKNS27 outbound calls should work after activations whether they are new numbers or ported out ones. 🙂
@vivienne
Your phone should work on PM.
Did you port your old number over to PM?
Or did you pick a new number?
If you ported over, you were to leave your old SIM in the phone and reply back to the text with a YES. You have 90 minutes to reply back.
If you missed this step contact a CS_Agent by private messaging (envelope icon above) or type in Create a Ticket by SiMon Chatbot at the bottom of the page.
MrSpock
@vivienne Hi manually turn to 3g in your settings that should help with phone calls if not you may have a provisioning issue with your account you will need to  open a ticket   to speak to a customer service agent ,   Click here or you can send private message to a CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
