acctivate Esim
Dougsw
How to Esim
hi @Dougsw
check this video
if you are existing customer and want to change to esim
https://www.youtube.com/watch?v=f9YXBRWxxJk
how to subscribe with esim (pay attention at 0:39)
https://www.youtube.com/watch?v=40LDBkpxJlo
Chalupa_Batman
@Dougsw wrote:
How to Esim
Hello @Dougsw
Are you currently with Public Mobile? If so, what phone do you have? If it's an iPhone, you may be able to convert your current physical SIM card like I did to an eSIM, depending on what iPhone you have. If it's an Android, all you have to do is go purchase an eSIM on the app on your phone, follow the steps. It's pretty easy to do. Best part, once you purchase one, all the next ones are free if you need to switch phones.
slusagm
esim is electronic sim.   But not all phones support it, check  your phone first
if your phone supports, download PM app, create an account, activate a plan and choose esim and follow the steps
