account problems
Bixby
I have two Public Mobile accounts, one for my daughter, one for me. Both are linked to the same email. I thought this wouldn't be a problem because with my previous provider, accounts were linked to the cel #, NOT the email. So here's the rub: I can access my daughter's "My Account" (had to update credit card info) but not mine. May I PLEASE speak to someone so we can fix this?
dust2dust
Did you sign up these two accounts before last July and in a store?
hairbag1
@Bixby
you'll have to contact a CSA to add a different email address to either hers or yours.
Top of this page, click Get Help / Chat with Simon to start process of CSA help. Give them as much acct info as you can
Watch the little envelop icon top right side of page will be highlighted when they respond.
Each account needs a unique email address...if you use gmail, you can use alias though.
@Bixby PM My account systm is one account/line  one email.  If you have 2 accounts , you must be using 2 different email to login or using email alias
if you are unable to login one of the account and not sure the email, open ticket with PM support:
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
