account increase
52-safety
why has public mobile decided to change the charge rate on two of my accounts ,as i didn't authorize
2 REPLIES 2
Meow
No more monetary rewards!
No more loyalty nor autopay nor referral monetary credit every 30 days. Now you get 5% off your bill back in points, 10 points at anniversary and 1 point for every referral. If you participate in Community few more points could be awarded.
When you collect 15+ points you have to manually convert them to $15, it will not be automatic applied toward your bill.
Phil_Adelphus
@52-safety  It's probably not that they changed the rate but a result of the switch from $ rewards to points.  You'll start off paying the original price of the plan you subscribed to without the $ rewards and over time accumulate points 1 point = $1 that you can use for bill credits or discounted add ons.  You'll get 5% of your payments in points, 10 points on your PM anniversary and 1 point per month for referrals.  If you're on anything other than the $15 plan you might want to look at the newer plans available in your account, such as the $19 that replaces the $25 plan, the $29 for 10GB plan, or one of the 5G plans like the $34 for 50GB Canada US or Canada only but unlimited.
