01-06-2023 05:18 PM - edited 01-06-2023 09:14 PM
tried to activate an account for my cousin till i got to promo code then it would not work because i put in wrong number twice then it would not accept it pls help and can it be done the next day or do i need an agent
Joining Public
01-06-2023 09:13 PM
i tried that did not work
01-06-2023 05:42 PM
hi @porcupine chexk your credit card and see if PM already charged you
if all good, try to use a different browser to try activate again
01-06-2023 05:21 PM
Hi there @porcupine do you mean referral code or promo code. Regardless if the promo code is valid a CSA should be able to add it for you after the fact.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
01-06-2023 05:21 PM
@porcupine Can you not just start over from the beginning ?
