account activation
08-11-2018 01:32 PM - edited 01-04-2022 06:43 PM
I had completed first page of account set up, working on porting my number from Fido. i had to go back a page and now the systems says my sim card is invalid. I can't continue
Joining Public
08-11-2018 01:40 PM
Close your browser. Restart your activation again.
08-11-2018 01:39 PM
You have two options you can try. You can either delete your cache and cookies or you can use incognito mode.
If you're using chrome, hold CTRL+SHIFT and then tap DELETE and let go of everything. From there select the time frame of all time and clear both cookies and cache. If you're using a different browser, navigate there through the settings.
An easier way is just to use incognito or private mode.
08-11-2018 01:35 PM
I am currently in the same predicament with a new number. I believe a freind had the same situation and discovered that it takes a few minuted to get it activated. Wait for 1/2 hour and try again.
