05-28-2020 02:14 PM - edited 01-05-2022 12:04 PM
Probably a stupid question. Can your voicemail be accessed with a third party mobile phone in the same way as using a landline?
05-29-2020 08:51 AM
From *any* other phone you can either dial your own number and press 1 once it gets to your voicemail announcement, or to skip ringing your own phone you can dial any of the local numbers across Canada on this list:
05-28-2020 02:21 PM
@xaugh wrote:Probably a stupid question. Can your voicemail be accessed with a third party mobile phone in the same way as using a landline?
Good question...yes you can.
05-28-2020 02:20 PM
@xaugh yes it can you can call your number and once the recording is finished press the * key and enter your pin
