Your id
12-02-2022 06:44 PM
Hello I need to reset my user name and password for my account as its urgent my plan got off I a able to call someone I need update my credit card information kindly advise it would be great help
My Account
12-02-2022 06:59 PM - edited 12-02-2022 07:00 PM
@shaikh wrote:Hello I need to reset my user name and password for my account as its urgent my plan got off I a able to call someone I need update my credit card information kindly advise it would be great help
Hi @shaikh
Was your username and password compromised? Or are you looking to port out elsewhere and need access to remove auto-pay from your account?
If so, definitely contact the CSA's as follows:
- Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
- Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
12-02-2022 06:46 PM
PM has NO phone/live support.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
