07-28-2022 11:42 AM
12-02-2022 07:15 PM
Yes
07-28-2022 06:41 PM
@1234567 wrote:Dies that stop the phone working after the first payment or do they just keep it open racking a bill up in my name?
There are no bills that you have to go back and pay. Disabling pre-authorized payments stops payments. If you don't pay, the service stops working.
07-28-2022 03:53 PM
07-28-2022 01:08 PM
- Remove autopay. Account will be deleted after 90 days.
- Port out - account will be closed immediately.
07-28-2022 12:18 PM - edited 07-28-2022 12:19 PM
You can also call 611 from the public mobile device and disable Autopay.
Then after 90 days of nonpayment your account, phone number and access to self service will close automatically.
If you have enough funds for your account to renew, you can log into your account to list your phone in lost/stolen status. This status will also close your account after 90 days.
Porting your phone number from here to somewhere else also automatically closes your account here.
edit tag @1234567
07-28-2022 11:48 AM
Do you have a bit more info? Do you just want to cancel your line or port out?
07-28-2022 11:44 AM - edited 07-28-2022 11:46 AM
@1234567890 🙂
Are you trying to "cancel" the line or porting out?
If cancel, you just need to disable Pre-Authorized payments. PM would not be able to charge you on your next renewal and your account will then be suspended. 90 days later , the account will be permanently closed
If it is porting , are you porting out? You are waiting for the text?
