12-02-2022 06:37 PM - last edited on 12-02-2022 06:40 PM by computergeek541
12-02-2022 06:40 PM
@goldstar wrote:can you retrieve a recently deleted voicemail?
Call yoour voicemail. Recently deleted vociemail messages essentially go into a "trash can" that can still be accessed. If messages are still there, you will be given the option to listen to recently deleted messages. Otherwise, they can't be retrieved.
12-02-2022 06:40 PM - edited 12-02-2022 06:43 PM
I believe only while you are in the voicemail system, @goldstar
Here's an older article re the voicemail menu for you to peruse: (can't verify its current status...)
What are the key features and menu options of Voic... - Community (publicmobile.ca)
