06-07-2015 09:13 PM - edited 01-04-2022 12:39 PM
Hi, I am wondering if the Xiaomi Mi4 I am planning on buying would work with Public Mobile?
Here are the specs: http://www.mi.com/en/mi4/specs/
Thank you in advance!
David
Phones
06-07-2015 11:09 PM
Do not purchase Xiaomi (a Chinese phone) because It's hell to deal with them for the warranty,
Plus, Xiaomi phones are incompatible with Canadian LTE networks.
06-07-2015 09:49 PM
According to my research, both versions lack 1700 MHz for 3G voice communication.
The 4G LTE version is incompatible because it is not HSPA+ enabled.
In conclusion, I would recommend another phone, with the following frequencies: 850 MHz and 1900 MHz for 3G voice, and 1700 MHz and 2100 MHz for HSPA+ data.
You can buy such phones at Staples, Best Buy, Telus online, Costco, Walmart, London Drugs, and Amazon.
06-07-2015 09:33 PM
There are 2 versions: 4G LTE and WCDMA. Which will you be buying?
