Xiaomi 14 pro mainland version compatibility
newbee25
Hi There,
Does Xiaomi 14 pro mainland version work on public network?  there is nowhere to set up the SIM network options to 5g/4g. Fido only can set it to 3g now.
Thanks,
Newbee
1 REPLY 1
hi @newbee25
yes, the phone will work here, but it might not work great on 4G and 5G as the phone does no have all the bands PM uses.
and the phone is not on VoLTE list, so you might be stuck with 3G voice.  However, you can try this trick to turn on VoLTE
 Dial * # * # 86583 # * # *. Once you are done, there will be a message ” VoLTE Carrier check was disabled ” appear on the screen, thus activating Volte on your Xiaomi phone. The message disappears quickly.
