06-09-2025 05:26 PM
Hi! I didn’t get an email, nor did my eSIM download to my cell. I am stuck in pergatory
06-09-2025 07:39 PM
hi @RyanRW
did you check the sim card manager? the app should install the esim for you. Check Sim Manager or Settings-> Cellular
if not there, you can ask PM support agent to help, you can submit ticket by direct message:
