Xiamoi mi a3 comparability
CZ
Hello. My phone doesn't show up in the options to check compatibility. Anyone know if it'll work?
Xiamoi mi a3 unlocked currently with Virgin.
CS_Agent
Customer Support Agent
Hi there, @CZ!
We have a section on our website where you can check the phone's compatibility with our network!
What you have to do is just to click on the following link and then to go to "1. Check your phone's compatibility"
https://www.publicmobile.ca/en/bc/get-started
All the best,
Ella PM Mod Team
geopublic
@madhi19  That is the Android One version and will work for the majority of North American providers.
madhi19
The a3 is pretty recent so it no surprise that the compatibility lists are outdated. My a2 work with PB for what it's worth.
popping
@CZ
Check the model number 0f your phone which you have against the list in this list to determine whether your phone works with PM or not.
https://www.frequencycheck.com/carrier-compatibility/gnkm5/telus-canada/devices?utf8=✓&q%5Bfull_name...
Dunkman
@CZ
It will work with Public mobile.
3G bandsHSDPA 850 / 900 / 1700 / 1900 / 2100
4G bandsLTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 20(800), 28(700), 38(2600), 40(2300)
https://www.gsmarena.com/xiaomi_mi_a3-9769.php
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
cavemantoronto
If it works on Virgin 3g network, it will work here.
