03-07-2019 07:28 PM - edited 01-05-2022 06:48 AM
I just went to Walmart to sign up for Public Mobile, transferring from Telus with the intention of keeping my existing cell number. The transfer quick and easy....WRONG! For some reason my old landline telephone number (which has been out of service for 6 months) became my new PM cell number. Went back to Walmart but they couldn't help. I do want my old phone number, I want the Telus number that should have been transferred in the first place. Please help!
03-16-2019 09:52 AM
Spoofing caller ID is incredibly easy
Better off to block it though (in case other person calls back)
@SomeFriend wrote:Say, with such, can’t people exploit it if they need a specific number as their caller ID?
03-15-2019 06:33 PM
03-15-2019 03:17 PM
@kav2001c wrote:You can't transfer a number "out of service" for 6 months (landline or cell)
Not possible
The "correct" test of a port-in is the ability to receive incoming calls. PM has a history of allocating the requested number for outgoing calls immediately. Suspect the number in question is not in use.
03-15-2019 02:56 PM
@jeremiah10 wrote:Hey Chrich66
First off, make sure your Telus cellular line is active and is making out going calls/in coming calls. Next log into My account on self serve on public mobile, and request a number change. Provide the phone number, account number and pin number. If that doesnt go through, you can contact the Moderater team and provide them the information through a private message. Do not post your personal info online.
Hope this helps, enjoy your day.
Agree, this is something you can do yourself in the self-service. That will be faster than waiting for the moderators, although if you have issues they should be able to help too.
03-15-2019 11:01 AM
Hey Chrich66
03-08-2019 11:47 AM
Hey dont curse me now ![]()
Something else happened in backend in all seriousness
Walmart could not have physically done this
It seems most likely error is on Bells side (as porting landline takes all kinds of extra verifications that do not exist for port a mobile number)
03-08-2019 11:42 AM
Well kav2001c all I know is that we no longer have a Bell landline. Wish you were my Walmart rep so that this wouldn't have happened!
03-08-2019 11:26 AM
Not possible
03-08-2019 11:20 AM
Yes I guess I should have, but my husband transferred 2 other phones at the same location with no problems I didn't think twice. Also, it was our old Bell residential number which was canelled more than 6 months ago so I am surprised it let him use it.
03-07-2019 07:42 PM
@chrich66 wrote:I just went to Walmart to sign up for Public Mobile, transferring from Telus with the intention of keeping my existing cell number. The transfer quick and easy....WRONG! For some reason my old landline telephone number (which has been out of service for 6 months) became my new PM cell number. Went back to Walmart but they couldn't help. I do want my old phone number, I want the Telus number that should have been transferred in the first place. Please help!
If you Telus account is still active just login into slefserve.publicmobile.ca or click on the My Account (Top right of this page), login into your account and there is an option to port your number.
If it does not work the send a private message to: moderator_team and they will help you. Good Luck!!
03-07-2019 07:39 PM
03-07-2019 07:33 PM - edited 03-07-2019 07:34 PM
@chrich66 Yoiu can try porting in from your self-serve account. If it does not let you, you will need to send a private message to the Moderator_Team and they will get get this figure out.
