05-05-2023
03:44 PM
05-05-2023
04:16 PM
computergeek541
I put the wrong number in when I signed up to transfer from Chatr. How do I change this?
05-05-2023 04:02 PM
No worry. There is a number to call to talk to live support, . Call them and provide them the correct info amd they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
