10-07-2021 07:31 PM - edited 01-06-2022 03:30 AM
Hello:
I called my friend today and realized that my caller id is a company name, could you please remove that?
Regards,
10-07-2021 07:35 PM
@linhvuuk : Public Mobile does not transmit the name of the caller. Just the number. Your recipient might have your number related to that business as a contact. Or they're using a database that still thinks that number belongs to that business.
10-07-2021 07:35 PM
10-07-2021 07:35 PM
@linhvuuk PM does not sent name info on caller id.
the issue is either your friend's has your number setup as a contact and entered the wrong name (the company name) or your friend has used some kind of name resolve services but this is out of PM control.
You can try to call other friends or your home and you should see only your number is displayed
10-07-2021 07:35 PM
but i don't think so public mobile has a caller ID display, but you can try to Contact Customer Support Agent by CS_Agent ,and Explain your issue to they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck..
10-07-2021 07:36 PM
@Anonymous pretty sure PM won't be able to help so I guess the ticket is not needed. PM only send number info as Caller id
10-07-2021 07:37 PM
@linhvuuk : You don't need to waste the time of the CSA's. It's not this end.
10-07-2021 07:38 PM
10-07-2021 07:39 PM
@linhvuuk : Those call display and call block options are for your incoming calls. Not relevant.
10-07-2021 07:42 PM - edited 10-07-2021 07:44 PM
@hTideGnow wrote:@Anonymous pretty sure PM won't be able to help so I guess the ticket is not needed. PM only send number info as Caller id
maybe the number have he/she has not probably right in account, and they CSA have to check it you know.
*There are three main circumstances that cause a caller ID to be displayed incorrectly: The originating carrier may have incorrectly formatted or not transmitted the original "From" number. This usually results in a missing caller ID, or a "translated" number code.
10-07-2021 07:43 PM
the name display wrong issue is on your friend's end.
A quick way to resolve it is to ask your friend to check if he has created the contact with wrong name. If he does not have a contact created for your number yet, create one and they would override whatever name lookup app/service he is using
if you want everything perfect, ask him what name lookup app he is using and open a ticket with that app owner to try to change it on his or her database.
