07-13-2024
02:08 PM
07-13-2024
03:14 PM
computergeek541
I just ported my number. I can't login to the site anymore because its trying to text to my old number. please fix. why is this such a problem? how can this not be automated?
07-13-2024 02:42 PM
common problem when number change
use Chatbot to open ticket and ask them to update it in the account
07-13-2024 02:27 PM
hi @gary123123 click Didnt receive code and then Send email
after you login , go to Profile, Manage EverSafe ID and update the phone number
if you cannot login at all, then you need to ask support agent
you can submit by direct message:
07-13-2024 02:17 PM - edited 07-13-2024 02:28 PM
@gary123123 If you can get signed in thru email instead . Go to profile page and click manage ever safe ID and update your new number there . Then you will have code sent to phone . If you can’t log in get support to update it for you
private message to support .
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
07-13-2024 02:13 PM
Not sure how to change the number but you can click on did not get code and have it sent to your email instead
